Forums >> General Discussion >> Revit Project Management >> Phasing Setup
Tue, May 15, 2012 at 2:54:08 AM | Phasing Setup
yilin1985
I am working on a renovation project and will be in charge of setting up the Revit file.  The intent is to have an Existing & Demo plan - showing existing walls as solid and demo as dashed.  As well as a New Construction plan - showing existing walls (minus demo walls) as grayed out with New walls solid hatched in.
I need some feedback as to how the phasing should be set up - whether to set up 2 phases; 1. Existing & Demo, 2. New Construction. Or set up 3 phases: 1. Existing, 2. Demo, 3. New Construction.
I have marked up an attachement below.  Can someone take a look and let me know?
Greatly appreciated!
Tue, May 15, 2012 at 7:58:55 AM | Phasing Setup
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We use an Existing, New Construction, and Project Completion. With the attached Filters.
Tue, May 15, 2012 at 10:43:09 AM | Phasing Setup
yilin1985
Which phase did you place demo on?
Tue, May 15, 2012 at 10:49:59 AM | Phasing Setup
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
New Construction
Tue, May 15, 2012 at 10:54:37 AM | Phasing Setup
We show demo on our existing views.
Tue, May 15, 2012 at 11:05:14 AM | Phasing Setup
yilin1985
@ WWHub - Can you confirm:
So you only had 2 phases? 1. Existing & 2. New construction?
And you demo'd on existing?
Thank you.
Tue, May 15, 2012 at 11:06:30 AM | Phasing Setup
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes we have a Demolition Plan View, Existing Plan View, New Construction Plan View so our demo is shown on our Demolition Plan View but is on the New Construction Phase with the Show Previous + Demo Phase Filter
Tue, May 15, 2012 at 11:22:40 AM | Phasing Setup
rod23
5 Stars: 4 Votes
Demolition is considered "new construction".  Control the view settings with the phase filters.
http://www.turbosquid.com/Search/Artists/Revitaoist
Tue, May 15, 2012 at 11:57:05 AM | Phasing Setup
Polar
I have had trouble getting artifacts of patched windows as solid lines in elevation and 3D views using only 2 phases, existing and new construction. (those artifact show up in the attached image).
When you add a third phase (demoltion - between exiting and new construction), as you have shown in your initial post, the line artifacts at over lapping and patched windows can be avoided.
I use phase filters all the time, but I have never created my own so it is possible that the need for a 'demo' phase can be eliminated by the right kind of custom phase filter.
You might consider completely modeling the existing building and saving it under another name before starting to model demolition and new construction.
think it - build it
Tue, May 15, 2012 at 12:07:49 PM | Phasing Setup
There are really no hard rules here.
Typically we never show demolished on new floor plans because that is a construction phase that typically starts first and is finished before you start new.  So we show demolished on demo plans with existing. < Phase filter set to show Previous and Demolished.  Then our planas are existing to remain and new.  < Phase filter set to show complete
Tue, May 15, 2012 at 12:58:39 PM | rod23
#11
4 Stars: 205 Votes
Quoting rod23 from 2012-05-15 11:22:40
I agree!
Existing: Show All - Existing
New Construction: Show Previous + New - New Construction
Demolished: Show Complete - New Construction
"There are really no hard rules here.
... that is a construction phase that typically starts first and is finished before you start new." - Correct, Here in Portugal we have "hard" rules for that, they want 3 plan views (elevations and sections also...) in the order I posted above.
Tue, May 15, 2012 at 12:59:17 PM | Phasing Setup
#12
yilin1985
I'm leaning to having just 2 phases; 1. Existing & Demo, 2. New Construction. That way I don't need to keep track or make a third view for every Demo plan if I were to have 3 phases.  The only concern is I don't want to run into graphic problems mentioned by Polar.
WWHub: did run into similar issues expressed by  Polar ? Or were you able to troubleshoot by modifying the phase filters/graphic overrides?
Tue, May 15, 2012 at 1:29:05 PM | Phasing Setup
#13
We don't have any problems but we don't really have a 'Revit' demo phase, just existing and new.  It is existing elements that are demolished but they are demolished in new construction phase.  Our phase filter graphic settings set how to show demolished as well as existing and new for our two document conditions plus a couple of others conditions we sometimes use while working.
Phasing - Building Already Done but Dind't Set up Phasing
Tue, Dec 15, 2009 at 7:40:42 AM
phasing
Tue, Oct 23, 2012 at 8:20:21 AM
Phasing moved to Visibilty/Graphic
Wed, Nov 18, 2009 at 4:11:56 PM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:00 PM
PHASING
Tue, May 20, 2008 at 1:57:25 PM
Page generation time: 0.2337
