Forums >> Revit Building >> Technical Support >> Roof sheet profile.
Mon, May 14, 2012 at 9:56:26 PM | Roof sheet profile.
Pele
Pele Avatar
I want to show a metal deck (Australian stramit profile from steel select) but cannot figure out (remember) how to do it.
I have downloaded the profile family but cannot work out how to include it in the section i am drawing.
Help would be much appreciated!!
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Tue, May 15, 2012 at 4:31:28 AM | Roof sheet profile.
4 Stars: 205 Votes
You need to include that profile in your floor structure. select the floor, goto properties and add a new layer then change the function to structural deck and select your profile.
Tue, May 15, 2012 at 6:31:22 AM | Roof sheet profile.
Pele
Pele Avatar
Thx Typhoon I was able to create a floor with a deck & change the layers to leave just a deck & no concrete, well at least just a 2mm line of concrete. But I cannot see where I can change the profile that came in the options in the structural editing dialog box.
It is actually a roofing ribbed profile deck that I wanted to create, but a floor deck would be fine if I could do the one I want.
Cheers Dermot
www.dmbd.net
Tue, May 15, 2012 at 6:41:38 AM | Roof sheet profile.
Pele
Pele Avatar
I have added an image of the roof I require the roof with a deck profile on
Cheers Dermot
www.dmbd.net
Tue, May 15, 2012 at 7:16:24 AM | Roof sheet profile.
We don't model these in most cases.  We use a material.
Tue, May 15, 2012 at 9:23:01 AM | WWHub
4 Stars: 205 Votes
Quoting WWHub from 2012-05-15 07:16:24
DITTO.
If you really need that in 3D you can use the "Slope Glazing"
Tue, May 15, 2012 at 6:38:26 PM | Roof sheet profile.
Pele
Pele Avatar
looks like I am not describing my requirements correctly. When I do a section cut I want the profile of the metal to show in the section drawing. Sort of like the insulation detail or like a continuing line of bricks?
Cheers Dermot
www.dmbd.net
Wed, May 16, 2012 at 3:49:02 AM | Roof sheet profile.
4 Stars: 205 Votes
Repeting Detail
Wed, May 16, 2012 at 7:46:01 PM | Roof sheet profile.
Pele
Pele Avatar
Ah Ha that sounds like what I want! now I will try to find out how to make it work!!
Cheers Dermot
www.dmbd.net
Thu, May 17, 2012 at 4:02:50 AM | Roof sheet profile.
4 Stars: 205 Votes
We don't give you the fish, we teach you to fishing.... In your HELP menu search for "Repeating Detail" and you will see the whole process.   Winking
Thu, May 24, 2012 at 8:09:13 PM | Roof sheet profile.
#11
Pele
Pele Avatar
"Array" seems to work my fishing is not very successful!!
I thought it would be reasonably easy but it looks like I have to get over the Family hump first, I have attached the profile I wanted to use for the repeating detail.
Cheers Dermot
www.dmbd.net
Metal deck roof profile
Fri, May 13, 2011 at 1:05:51 PM
Profile Sweep over Roof Cricket [ 1 2 ]
Fri, Sep 7, 2012 at 12:47:31 PM
27
Roof Edge Profile
Sat, Aug 26, 2006 at 11:08:27 AM
Roof Profile
Sun, Dec 3, 2006 at 9:42:42 PM
How to create Roof Sheeting profile 28 metres wide
Thu, Apr 23, 2009 at 8:36:26 PM
Page generation time: 0.3917
