Forums >> Revit Building >> Technical Support >> Modeling/Creating Galvalume Edges in Revit...help!
Mon, May 14, 2012 at 12:21:06 PM | Modeling/Creating Galvalume Edges in Revit...help!
ddfrazee
I am currently trying to create a "corner wrap" from the wall around the roof (See leftside attached pic, where the galvalume goes up, around, and frames the wood siding)...where do I even begin to do something like that inside revit? I would imagine I just have to model all of corners...and assign them as "walls" or "roofs." But that just...doesn't seem right to me. Is is a wall sweep issue? Very stuck here...
Thanks,
DDFrazee
Mon, May 14, 2012 at 12:26:39 PM | Modeling/Creating Galvalume Edges in Revit...help!
Are you asking about a Rake Flashing?  This could be a roof edge sweep.  You can do it in place or use the roof facia tool < that would be better.
Mon, May 14, 2012 at 12:31:34 PM | Modeling/Creating Galvalume Edges in Revit...help!
ddfrazee
Thank you very much! That definately solves the roof problem...
however the exterior/outside corner of the two walls, is still giving me grief...I cannot seem to find a tool that could cap the corner... any suggestions there?
Mon, May 14, 2012 at 12:58:03 PM | Modeling/Creating Galvalume Edges in Revit...help!
I would use a vertical wall sweep there.  This is a flashing in real life ... and so it is in Revit.
Mon, May 14, 2012 at 3:18:25 PM | Modeling/Creating Galvalume Edges in Revit...help!
ddfrazee
Problems: SOLVED
Cheers to and you and Revit both!
creating a chamfer on edges of an extrusion
Tue, Apr 21, 2009 at 5:47:05 PM
Swimming Pool rendering with dark edges
Fri, Feb 22, 2013 at 7:49:38 AM
Unable to open Revit Model .Error -This family instance has too many edges.
Mon, Oct 6, 2014 at 6:02:41 AM
Modeling Tutorials
Wed, Dec 10, 2008 at 11:08:19 AM
sketchup imports dont show edges withing planar facees
Tue, Mar 6, 2018 at 5:59:52 PM
Page generation time: 2.3221
