Forums >> Revit Structure >> Technical Support >> Altering Revit Structure Wood Beam Families
Mon, May 14, 2012 at 10:52:09 AM | Altering Revit Structure Wood Beam Families
SofiaClark
I need to change the wood beam families to show an "X" in the beam when creating a section or elevation.  I've been able to do so with the wood column families but not beams.  Can anyone provide any information on how to do this?  I've tried model lines and symbolic lines and then save the family but the "X" still doesn't show up in my model.  I am using Revit Structure 2012.  Thank you.
Mon, May 14, 2012 at 1:15:27 PM | Altering Revit Structure Wood Beam Families
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What beam family are you trying to change?  I did it with the Structural Framing/Wood/Dimensional Lumber family.  I drew in the "X" aligned and locked it to the Reference Planes so that it will stretch with the beam when the size is changed then clicked on the 2 lines that form the "X" and clicked Convert Lines to make them Symbolic lines and brought it into the project with everything working fine.
Mon, May 14, 2012 at 1:28:17 PM | Altering Revit Structure Wood Beam Families
SofiaClark
I'm trying to change all of the wood beam families.  I'll try your suggestion.  Thank you!
Mon, May 14, 2012 at 2:10:01 PM | Altering Revit Structure Wood Beam Families
SofiaClark
To teafoe5,
What do you mean by drawing the lines "aligned"?  What view did you draw your lines in?  3D, Left, or Right?
Thank you.
Revit Structure 2008 SP2: Join Geometry on differnet beam families
Wed, Sep 19, 2007 at 11:58:38 AM
Built-up wood beams?
Mon, Apr 3, 2006 at 9:29:26 PM
Detailing a Beam Saddle at Valley Beam
Wed, Jan 26, 2011 at 12:15:21 PM
Wood frame structure Family
Sun, Feb 20, 2005 at 7:00:17 PM
REVIT Structure and Architecture for wood framed buildings
Thu, Apr 18, 2019 at 2:38:02 PM
Page generation time: 4.3352
