Forums >> Revit Building >> Technical Support >> problem with mullion
Fri, May 11, 2012 at 4:18:00 PM | problem with mullion
pedram90
Hi
I have Revit Architecture 2012. when i want to use mullion command,
the revit say: "No Curtain Wall Mullions family is loaded in the project, would you like to load on now?"
and i have tried very families to load but no one could be loaded
Is there any body to help me?
Sat, May 12, 2012 at 3:11:01 AM | problem with mullion
Polar
Hi Pedram,
I have had a similar problem with annotation - tags not loaded even when I tried to. The problem seemed to have more to do with whether they were entities in a referenced Revit file or stuff actually in the file I had open.
Maybe Revit reports that error to you when it's really something else?
think it - build it
Sat, May 12, 2012 at 8:31:22 AM | problem with mullion
pedram90
Hi Polar
No I haven`t seen Revit error till now. I think this problem is because of Metric Template that I use in Revit.
The default template in my Revit is Imperial, I can`t work with Imperial unit(foot & inch).
In my country the Metric unit is common. So I have to use Metric template
problem with horizontal mullion
Mon, Oct 31, 2011 at 2:44:39 PM
Storefront mullion malfunction
Fri, Feb 10, 2006 at 10:20:55 AM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:54 AM
Page generation time: 7.7563
