Forums >> General Discussion >> Revit Project Management >> Creating Floor At same level but with different raise.
Fri, May 11, 2012 at 3:28:59 AM | Creating Floor At same level but with different raise.
valmik27
hey friends, i know to create a floor, but how can i create a floor with a bit high raise at some part at same level.
Suppose m creating floor at Level 1. once i create it, i need sme part of floor to raise a bit.
how can that be done? pls help.
Fri, May 11, 2012 at 3:42:39 AM | Creating Floor At same level but with different raise.
4 Stars: 205 Votes
You can add extra points/lines to your floor and increase the elevation of those points/lines, check in your help "Modified sub-elemets".
OR you can create another floor on top of the other and join them.
What determines the level of insertion for objects in a revit view?
Tue, Jan 20, 2015 at 1:21:17 PM
everything inserting on the wrong level?
Mon, Jul 9, 2012 at 11:09:27 AM
Creating different floor heights on one level
Sun, Oct 11, 2009 at 7:54:06 AM
create cellar level/floor plan below level 1 afterwards
Mon, Jun 26, 2006 at 8:24:52 PM
Single Floor with multiple levels
Tue, May 14, 2013 at 10:24:40 AM
Page generation time: 0.4633
