Forums >> Revit Building >> Technical Support >> copy with base point in revit
Fri, May 11, 2012 at 3:07:20 AM | copy with base point in revit
zulkarneyn
zulkarneyn Avatar
hi, i didnt get revit coordination sytem well coulndt understand.
i want to try copy paste between different phases of revit drawings but i cant use project base point.i copy topography from one to other but when i try to paste i cant snap base point.i want to see old topography and new topograghy at same drawing.
i know its not like in autocad but i cant change location of the pasted element according to base point , its base point lost after pasted.
can you tell me with a simple way to do this.
Fri, May 11, 2012 at 7:03:41 AM | copy with base point in revit
If the object is in the same place, just copy to clipboard, paste same place.
RE: REVIT's Copy with a base point
Fri, May 15, 2009 at 11:22:04 AM
possible to delete project base point?
Mon, Apr 29, 2013 at 3:58:58 PM
Project Base Point
Thu, Jul 2, 2009 at 6:24:59 AM
Project base point moved after I created levels
Fri, Jan 8, 2016 at 1:27:49 PM
Shared Project Base Point
Tue, Mar 16, 2010 at 9:45:58 AM
Page generation time: 3.7513
