Forums >> Revit Building >> Technical Support >> custom tags
Thu, May 10, 2012 at 2:56:44 PM | custom tags
Gitaroo
I have made a bunch of windows with curtian wall tools now I am trying to create a custom tags for all my curtian walls so they are not all link together as a wall using same same Mark. Like instead of say EW1 for everything even though they are in different size. Basically no share parameter, instead I type in the name/mark manually myself. Any tips? Is there any parameter that I can use that is not shared?
Thu, May 10, 2012 at 4:02:23 PM | custom tags
Curtain walls are a wall.  So we modified a wall tag to look like our window tags and that reads the wall mark number.  < Instance parameter.
Thu, May 10, 2012 at 4:11:27 PM | custom tags
Gitaroo
ya, problem is the mark number is he same for all my CW, even though they are in differnt size, anyway manual overwrite method that allow me to type in my own number or any label option that doesnt link itself to a parameter?
Fri, May 11, 2012 at 7:13:01 AM | custom tags
Wait a minute.....
There are two parameter types for almost every object's mark number.  One is instant based and the other is type based.  We Tag using the instance tag for curtain walls.  Thus every one can have a unique number.  We tag regular walls using the Type Mark.
UNDERSTAND?
Fri, May 11, 2012 at 9:57:27 AM | custom tags
Gitaroo
sorry, I am new to revit, so you suggesting to use a instance tag? I normally type in tg and tags everything, and swap when I have to. Is there such as thing as instance tag or do I have to create my own?
Fri, May 11, 2012 at 10:45:36 AM | custom tags
Edit your tag - you can see if it is instance or type that it points to.  Change it if needed and save under a different name.
Fri, May 11, 2012 at 11:07:14 AM | custom tags
Gitaroo
is that under label?
Edited on: Fri, May 11, 2012 at 1:15:24 PM
Fri, May 11, 2012 at 12:49:20 PM | custom tags
Yes ... the label points to the family parameter that it reads.
You can learn more about families by downloading " the families guide" from the autodesk site.
Fri, May 11, 2012 at 1:17:26 PM | custom tags
Gitaroo
I created a new generic tag with its family type set to instances instead of type, but whenever I tag it all the tag always revert back to wall tag. This is the problem I am having, I just want something that is basically like a dynamic block in CAD where you can drag and drop and label it as anything I want and can be use on anything. a 2D graphic basically.
Edited on: Fri, May 11, 2012 at 1:25:06 PM
Fri, May 11, 2012 at 1:22:45 PM | custom tags
This is not CAD - It is easier far if you learn to use it.
Did you set your tag family as wall category?  NO - I don't think so.
Did you load your new tak and switch to it to use it?  The answer is NO.
Fri, May 11, 2012 at 1:29:33 PM | custom tags
#11
Gitaroo
isn't it automatic, it will assign the catagory type to whatever the object is. That is why Im stuck with wall type when I tag the CW. But I want to use individual mark for all of them because I use the CW tools to create my windows. Like I said, I am new to revit. And I know it is not cad. My new generic tag I created it loaded in the project family, and I click create instance from there to tag the CW.
Edited on: Fri, May 11, 2012 at 1:47:26 PM
Fri, May 11, 2012 at 1:32:35 PM | custom tags
#12
Please download the families guide as I suggested.  It would also be beneficial to use the HELP and look at some on-line videos.
This program is great but you can't expect to learn everything here.
Creating custom tags & custom categories in Schedules function
Thu, May 26, 2005 at 6:57:27 PM
Creating custom tags & custom categories in Schdules function
Thu, May 26, 2005 at 6:42:45 PM
Creating Furniture Tags Custom
Tue, Feb 11, 2014 at 5:29:58 AM
CUSTOM KEY NOTE TAGS/ ROTATING VIEWS IN PLOT SHEETS
Thu, Feb 6, 2014 at 2:16:36 PM
adding arrow head to custom tags
Sat, Aug 3, 2013 at 9:49:15 PM
Page generation time: 4.4013
