Forums >> Revit Structure >> Technical Support >> isolated foundation tags
Thu, May 10, 2012 at 10:01:55 AM | isolated foundation tags
davidlowery
When I tag a pad footing, the tag appears right in the center of the pad, where the column is.  Why does Revit think this is good, and how do I get the tags to appear NEXT to the pad?
Thu, May 10, 2012 at 12:01:45 PM | isolated foundation tags
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The tag attaches to the edge of the footing or foundation with a leader that you can move around to read how you want.  On the options bar click the check box that says "Leader" if you dont it will automatically assume that you want it in the center of the foundation
Edited on: Thu, May 10, 2012 at 12:03:41 PM
RC detailing for isolated footing foundation
Sat, May 21, 2011 at 8:15:18 PM
Isolated Foundation atching to column base: Revit 2010
Thu, Jun 25, 2009 at 1:59:29 AM
Foundation Schedule - no footing thickness field - help!
Fri, Dec 2, 2011 at 10:24:44 AM
12
Changing Pile Types in Isolated Foundation
Tue, Mar 31, 2009 at 9:32:34 PM
Strip Footing not wanted in Foundation schedule
Mon, Mar 28, 2016 at 4:05:52 PM
Page generation time: 0.1496
