25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Topographical Surfaces
27 Posts No Rating |
Is there a way that you can create a topographical surface on any level other than the site level? the building i am working on has been drawn on the site level and so when i am creating the topo, the points i am using (from the topographical survey) are causing the topo surface to go up above the building because they are being offset from the site level rather than being offset from a point lower down which i would like to be the true 0.
All advise welcome. thanks
Kieran
Your using the wrong approach. Read about relocating your project in your HELP.
Topographical surfaces |
Wed, Dec 26, 2007 at 8:13:16 PM
Toposurface Surface Patterns |
Fri, Apr 16, 2010 at 10:42:53 AM
Topographical survey |
Fri, Dec 4, 2009 at 2:23:19 PM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
Cutting floor slab edges out of pads |
Mon, Oct 25, 2004 at 10:43:54 PM
