Forums >> Revit Building >> Technical Support >> Family - Schedule Host Parameter
Thu, May 10, 2012 at 5:45:10 AM | Family - Schedule Host Parameter
rmh1981
All,
We have been trying to schedule the host wall type for internals doors.  From what we've gathered from some earlier posts around 2008 this can't be done without using Revit API or similar.
Does anyone know if this has been addressed in Revit Architecture 2012 or 2013.
Regards
rmh1981
Thu, May 10, 2012 at 7:16:27 AM | Family - Schedule Host Parameter
Reporting Parameters
A reporting parameter is a parameter type that has its value driven by a particular dimension in the family model. Reporting parameters extract a value from a geometric condition and use it to report the data to a formula or as a schedulable parameter.
^^ As you can see, you can only read certain dimensions.  This could be a wall thickness.  Nothing else from the host.
Nested Family referencing Host family
Fri, May 10, 2013 at 7:15:14 AM
"Schedule Level" Parameter in Plumbing Fixture Family
Thu, Jul 3, 2014 at 2:32:51 PM
Host wall thickness, in door schedule.
Fri, May 31, 2019 at 4:26:18 AM
Pulling System Parameter From Nested Family
Wed, Jan 9, 2019 at 8:58:25 AM
Revit Element to Use Host Height as parameter
Fri, Mar 27, 2015 at 2:29:50 PM
Page generation time: 3.0365
