15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Door in System and Inplace-Walls Extracting Room Info
4 Posts No Rating |
Wondering is someone can help me or if anyone has had the same problem. We are working on a project which has both existing and new build elements. Where we have new build elements we are using the standard system wall, but in the area of existing we are using in-place wall. When we place a door into a system wall we can extract room information (Name / Number) but when we place a door into an in-place wall we cannot extract this information. Is anyone else having this problem? We are using Revit Architecture 2012.
S .
I can't say that I have ever seen that question.
Why are you using in-place walls rather than walls? Seems you will be creating lots of problems.
4 Posts No Rating |
Reason why we are using in place wall is that most of the existing wall are not straight, we created in place wall so they match the survey information we received
Did you add room seperation lines? If so, then these doors may be in no man's land.
4 Posts No Rating |
nope, rooms are enclosed with wall. i have also check, room, doors and walls are placed at the save level.
I just tried this and this does seem to be the case.
Sorry - I have no solutions for you.
4 Posts No Rating |
Thanks for trying,
Right pain.
room names not being picked up in door schedule |
Mon, Apr 21, 2008 at 10:26:48 AM
Door Swing Direction |
Thu, Sep 23, 2010 at 8:10:26 AM
automating door schedule ( From room # To Room #) |
Thu, Jun 20, 2019 at 2:14:07 PM
Associating Door Tag Labels to Room Tag Labels for Automated Door Schedule? |
Wed, May 13, 2009 at 3:16:32 PM
Door Schedule |
Fri, Aug 17, 2012 at 7:07:50 AM
