Forums >> Revit Building >> Technical Support >> Dashed lines in families are showing as solid lines in project
Wed, May 9, 2012 at 4:45:08 PM | Dashed lines in families are showing as solid lines in project
suedehart
suedehart Avatar
I have two separate instances of lines that are symbolic and should be showing as dashed (the second swing on a double acting door, the track above on a folding partition).  Is there a way that these lines are being overridden by my project settings?  When I go into "edit family" everything looks fine, and even when I am placing the family I can see the dashed lines.  However, once it is in place and I deselect it, the lines look solid.
Does anyone know why this would be?
Thanks!
Thu, May 10, 2012 at 8:21:55 AM | Dashed lines in families are showing as solid lines in project
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Check your line types in the Visability Graphics.
Thu, May 10, 2012 at 8:38:48 AM | Dashed lines in families are showing as solid lines in project
Always remember, THE PROJECT RULES.  Under the manage tab - object styles, check the settings for the door sub catagories.
Disappearing dashed lines?
Tue, Feb 21, 2017 at 2:16:48 PM
Symbolic Lines in Family - Display in Project
Fri, Jan 24, 2014 at 12:44:22 PM
hidden steel columns showing as solid
Tue, Nov 23, 2010 at 12:18:43 PM
Floor slabs showing dashed instead of Solid
Wed, Jun 5, 2013 at 5:53:00 PM
12
All new elements inserted are dashed/hidden lines
Tue, Jan 27, 2015 at 8:23:43 AM
Page generation time: 2.8021
