Forums >> Community >> The Studio >> Title block, not the usual question
Wed, May 9, 2012 at 5:44:21 AM | Title block, not the usual question
KES1
Hi guys,
I've a question regarding titleblocks with respect to QA and IP when issuing of models to clients.
In autocad our title blocks are set up so that whilst on our servers they display our company logo, full address etc but as soon as they are sent to a client/outside company these are removed and only our company name is displayed, obviously this is all handled using x-refs which work well.  What i'd like to know is if there is a way of doing the same in revit?I've had a bt of a play but cant quite get it to work how i'd like, for instance i cant link a cad file into our title block template.
Thanks in advance.
Wed, May 9, 2012 at 8:16:08 AM | Title block, not the usual question
Just make alternate title sheets and swap these out before sending the file.  We do this for our code submissions where we need an electronic stamp.  Simple swap this family in with the same name as your regular sheet family.  That will replace all instances.
Wed, May 9, 2012 at 8:56:38 AM | Title block, not the usual question
KES1
Excellent, that works a treat!
You spend ages trying to be clever about getting something to work and yet its always the simplest idea that actual ticks all the boxes.
Many thanks!
Simple Title Block Question
Wed, Jan 21, 2015 at 3:57:54 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
tag an imported dwg title block
Thu, May 12, 2011 at 12:34:13 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
Page generation time: 3.7633
