Forums >> Revit Building >> Technical Support >> Two-story windows, please help!
Tue, May 8, 2012 at 11:56:37 AM | Two-story windows, please help!
ashleyrogow
Hello!  I'm a beginner with Revit (I have Revit 2012), and I'm designing a simple house.  The issue I'm having is that I have a section of the house which is open to both stories, and I'd like to make a custom window that will be one continuous window going up both stories (about 15' tall), obviously with some frame divisions, haha.  I have no idea how to make a two story window, though.  I was messing around with some of the provided window families and when I change the parametrics to make it 15' tall (when it's on Level 1), it shows the windows in the floor plan on the second floor, but the window does not cut through the wall on the second floor.
Advice, please?  Thank you so much!
Tue, May 8, 2012 at 12:02:00 PM | Two-story windows, please help!
ashleyrogow
To be more clear (very very tired, words may fail me), I'm looking to make a custom family for something like this: http://blogs.orlandosentinel.com/.a/6a00d83451c3cb69e2011570ac8507970b-640wi
Tue, May 8, 2012 at 12:38:54 PM | Two-story windows, please help!
4 Stars: 205 Votes
Use "CURTAIN WALL" tool....
Tue, May 8, 2012 at 12:46:01 PM | Two-story windows, please help!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes Curtain Wall is your best option.  Check out this tutorial, there are also a lot more tutorials out there if you search for them.
http://www.youtube.com/watch?v=Cslf3jkOMV0
Tue, May 8, 2012 at 1:19:51 PM | Two-story windows, please help!
mdvandenakker
If you are using two separate walls for your first and second floor that could be the reason you are not seeing it on the second floor. Use the Cut command (Modify>Geometry>Cut) and click the window and the second floor wall so it understands to subtract the window from wall.
Wed, May 9, 2012 at 7:47:45 AM | Two-story windows, please help!
Polar
pretty sure I've done what mvanden.... suggested with success in the past
think it - build it
Cant cut two story windows in plan view
Fri, Aug 23, 2013 at 10:45:18 AM
How to model floor joists correctly in 2 story residential
Sat, Nov 28, 2009 at 8:35:09 AM
2 story areas
Tue, Jul 29, 2008 at 12:31:16 AM
New sections views show every story in my 75 story project!
Mon, Dec 23, 2013 at 6:43:12 PM
1 1/2 story house
Mon, Mar 10, 2014 at 6:59:21 PM
Page generation time: 0.2177
