Forums >> Revit Building >> Technical Support >> View Template Lost during 2012 to 2013 Upgrade
Tue, May 8, 2012 at 7:25:39 AM | View Template Lost during 2012 to 2013 Upgrade
viper11
We have recently upgraded from 2012 to 2013. The project I am working on had view templates associated with them during the 2012 session of work. I just noticed that none of the views retained the view templates that were associated with each view in 2012.
Has anyone else experienced this?
Tue, May 8, 2012 at 7:50:05 AM | View Template Lost during 2012 to 2013 Upgrade
Please report this to AutoDESK.
Tue, May 8, 2012 at 8:26:49 AM | View Template Lost during 2012 to 2013 Upgrade
viper11
All right ....here is the low down that I have just found out.
Don't panic, you have not lost any of the visibilty that you associated with the views. Since 2013 view templates are different than how 2012 worked they needed to disassociate the view template from each view.
Just beware that 2013 view templates are different and if you associate 10 views with a view template and change that view template all 10 views will change.
Upgrading from revit 2012 to 2013
Tue, Apr 23, 2013 at 9:34:40 PM
Metric Template and Library lost
Tue, Apr 8, 2014 at 6:55:07 AM
View Template Nightmare - 2013
Fri, Feb 22, 2013 at 8:29:22 AM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Revit Upgrade from 2009 to 2012
Wed, Oct 19, 2011 at 7:08:21 AM
Page generation time: 4.0089
