18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Scheduling Detail families
35 Posts No Rating |
HI all
I am setting up Revit for my office that specifies in designing buildings made from glue lam load bearing construction and rock wool elements as external covering. the Company produces those elements themselves. Therefore i need to make element drawings for the production.
My plan is to use system families as walls defined as the elements and on the elevations i wanted to use detail families with shared parameters that define each element type.
I need to be able to schedule those detail families but it seems to be impossible, does anyone have the solution for this?
I am also wondering if it is possible to put embedded details into system families so they will appear in cuts and plans?
I would really appriciate any help or suggestions of how to work around these problems
Thanks
Sigurjón
I have tried adding a shared parameter to the detail family and scheduling it as a multi catagory scehdule but it wont appear.
any suggestions?
I think i got this, I made a face based generic model with shared parameters that is visible in elevations, it works perfectly.
hope anyone can use this info
Detail Groups vs. Families - pros/cons? |
Wed, Mar 20, 2013 at 10:51:53 AM
Scheduling Problem with Face Base Families |
Tue, Jul 15, 2014 at 8:59:16 AM
Repeating Detail in Families |
Mon, Jul 2, 2012 at 3:30:47 PM
12
Scheduling multiple parking families |
Wed, Sep 7, 2011 at 7:50:18 AM
Changing the detail level in a large group of families...... |
Mon, Aug 26, 2019 at 4:44:53 PM
