Forums >> Revit Building >> Technical Support >> GRILLWORK TO FIT ARCHWAYS ON PORCHES
Mon, May 7, 2012 at 9:08:42 PM | GRILLWORK TO FIT ARCHWAYS ON PORCHES
CYBERCAT
1 Stars: 1 Votes
Hi I'M trying to place grillwork for arches beyween columns on a porch.How do i model this.I was able to do it with railings
by placing a floor on top of the lower walls on a straight surface.I'm struggling to get the railings to follow the the curve of the archway
archway above.Any help will be greatly appreciated.Please see attached file.
Tue, May 8, 2012 at 5:57:33 AM | GRILLWORK TO FIT ARCHWAYS ON PORCHES
4 Stars: 205 Votes
What image?
use a small PNG or JPEG file...
Wed, May 9, 2012 at 3:45:47 PM | GRILLWORK TO FIT ARCHWAYS ON PORCHES
CYBERCAT
1 Stars: 1 Votes
Please see attached file.Sorry, The last  attachment exceeded the file limit so it did not go through.Thanks for responding
i'm looking forward to solving this issue.
Wed, May 9, 2012 at 3:50:33 PM | GRILLWORK TO FIT ARCHWAYS ON PORCHES
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could do it as a seperate window family that would cut the wall exactly how you wanted it, or could use a generic model and model to your requirements and place in your opening or you could try using a curtain wall for this also.  What does the grillwork look like?  I see your drawing but is there something in a real life application you are going off of that we could look at to maybe better answer you?
Covered Porches in 2010
Tue, Dec 8, 2009 at 8:44:31 PM
How to bend my workplane to fit curtain surface... ?
Tue, Feb 24, 2009 at 8:05:40 AM
Railings - How to spread to fit glass panel balustrades?
Wed, Aug 19, 2009 at 6:24:01 PM
plotting view sheet set at a fit to page type default???
Tue, Jul 8, 2008 at 2:02:38 PM
Door Schedule Fit on Two Sheets
Wed, May 22, 2013 at 12:35:17 PM
Page generation time: 0.2294
