Forums >> Revit Building >> Technical Support >> SAT file not showing in elevation other views OK
Thu, May 3, 2012 at 12:59:28 PM | SAT file not showing in elevation other views OK
erickson1026
I just inserted an SAT file into Revit 2012.  The coffee maker model works OK in all views (plan and elevation shown) except the elevation.  Checked all the VG categories.  No luck
Any tips are appreciated.
Dave E
Thu, May 3, 2012 at 1:10:06 PM | SAT file not showing in elevation other views OK
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Check to make sure its not hidden and that your detail level is set to fine
Thu, May 3, 2012 at 2:07:42 PM | SAT file not showing in elevation other views OK
erickson1026
Thanks for that.  View set to fine and checked hidden elements.  No luck though. I have attached a screen shot.  If you look closely you'll see the coffee maker elevation in half tone.  Just doesn't show up in view.
David
Thu, May 3, 2012 at 2:16:17 PM | SAT file not showing in elevation other views OK
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you make this coffee maker?  I would check the family and make sure all of the settings are correct for viewing there also.  Otherwise try uploading the family and I'll see if I get the same results.
Thu, May 3, 2012 at 3:09:34 PM | SAT file not showing in elevation other views OK
erickson1026
I downloaded the SAT file from a sharing site, then created a family from it and inserted it as a component into Revit 2012.
I have attached the SAT and the RFA if you would like to take a look.
If it's a hassle don't worry about it.
Thanks.
sat file viewing problem
Fri, Jun 19, 2015 at 7:38:53 AM
Import a dwg without it showing in all views
Fri, Apr 29, 2016 at 10:25:47 AM
Import SAT file
Fri, Nov 30, 2012 at 9:42:19 AM
Elevation showing everything
Wed, Sep 21, 2016 at 2:40:12 PM
14
2010 Conceptual Massing and .sat files
Fri, May 27, 2011 at 12:46:18 PM
Page generation time: 1.3494
