Forums >> Revit Building >> Technical Support >> Brick rendering at wrong scale and sideways
Thu, May 3, 2012 at 11:53:14 AM | Brick rendering at wrong scale and sideways
shanegavitt
i am importing simple shapes into Revit from Rhino4 and when i render the shapes in brick they are rendering sideways and the bricks are too small. I have tried scaling the model down and changing the brick jpeg but it still is too small and since i am importing the model their are no hatch patterns in elevation that i can rotate to fix the brick coming in sideways. thanks in advance for any help,
sg
Thu, May 3, 2012 at 3:45:22 PM | Brick rendering at wrong scale and sideways
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you are adding a brick material to the shapes?
Thu, May 3, 2012 at 5:18:51 PM | Brick rendering at wrong scale and sideways
shanegavitt
yes, i am just applying the brick to the shapes and i have tried making the brick jpeg bigger and smaller but it doesnt affect the scale that its applied. If i have to rebuild the shapes in revit i can but it would be tough to build it at a scale small enough to show the brick properly.
Thu, May 3, 2012 at 5:44:32 PM | Brick rendering at wrong scale and sideways
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Go to the Manage tab, and hit the Materials button.  Browse to the brick material, hit the Apearance tab.  CLICK on the image.  Not the cube--the rectangle englargement of it.  This is the texture editor, and you can rotate the image, and resize the scale at which revit repeats the image.
Bricks are twisted... materials going up instead of sideways
Thu, Jul 21, 2011 at 2:30:06 PM
Adjust Brick veener to move down agianst the brick ledge.
Thu, Jul 26, 2018 at 2:23:13 PM
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:04 PM
Rendering A Brick Soldier Course
Sun, Oct 9, 2005 at 11:12:30 PM
Page generation time: 0.3191
