Forums >> Revit Structure >> Technical Support >> Change Angle of referance plane?
Thu, May 3, 2012 at 5:29:21 AM | Change Angle of referance plane?
CraigB11
Hi, i am try to change angle of ref. plane for a roof slope.
When i select the ref plane and change the angle, it rotates the line around the mid point of the line.
I need it to rotate around the setting out point of the rafter (eaves lvl). Is this possible? ie. i have 3 degree pitch and i want to change it to 4 degrees, but need to keep start lvl of rafter.
Cheers,
Thu, May 3, 2012 at 5:56:51 AM | Change Angle of referance plane?
4 Stars: 205 Votes
Just DRAG the rotate icon to where you want.
Thu, May 3, 2012 at 8:48:11 AM | Change Angle of referance plane?
Johnzo142
You can also hit the space bar after starting the rotate command and place the rotate origin by clicking the point you wish to rotate from.
Thu, May 3, 2012 at 8:56:49 AM | Change Angle of referance plane?
CraigB11
Thanks for that.
referance point
Wed, Mar 19, 2014 at 11:18:27 PM
Window Host Referance
Wed, Sep 23, 2009 at 12:53:03 PM
Changing angle of celing plane(09')
Tue, Feb 23, 2010 at 1:06:31 PM
Flat roof with crickets
Mon, Jun 9, 2008 at 3:50:45 PM
Complex Steel Columns
Tue, Jul 1, 2008 at 10:21:51 AM
Page generation time: 6.2858
