19 Users Online (17 Members):
Forums >> Community >> Newbies >> About sphere truss..HELP!
2 Posts No Rating |
How can i build a truss around the sphere??? Thank you so much..
Now I am using a mullions, but how can I change it to be a truss system...
(Sorry about the bad english)
Model a component, probably an extrusion, to do what you want.
2 Posts No Rating |
Model a component???
thats mean i should use a Metric Generic Model to build it??
how can i import my massing into a Metric Generic Model...btw thank you for your answer
Yes.. Load your mass into a project and use the Model-In-Place option
Radial array is your friend. Here are some sloppy sattelite dishes we have gracing a property next to ours... just modeled one truss, and arrayed it 20 times around the dish. Looks pretty convincing, and in the end took about 5 minutes.
Create a mass and divide its surface. Then, in a 3d view with the mass visible, use the beam tool with the pick line option. Square beams have a tendancy to twist in strange ways, but pipe beams would look great with no modification. See the attached files.
Here is the RVT (2013) file
Apparently I cannot attach the rvt file.Edited on: Thu, May 3, 2012 at 1:00:59 PM
Edited on: Thu, May 3, 2012 at 1:01:44 PM
Truss overhang help |
Wed, May 23, 2012 at 8:32:23 AM
Need help cutting varying size holes through sphere? |
Tue, Sep 18, 2012 at 3:53:24 PM
One for Mr. Spot |
Tue, Oct 25, 2005 at 8:03:49 PM
Truss - Rotating |
Thu, Feb 6, 2014 at 9:10:40 AM
Trying to void a spherical mass in 2012 |
Wed, May 18, 2011 at 1:22:23 PM
