Forums >> Revit Building >> Technical Support >> Can you rotate wall sweeps?
Wed, May 2, 2012 at 4:49:15 PM | Can you rotate wall sweeps?
wedickerson
I am woring on a building the has a cable roof and want to place a crown running up the soffit on the gable roof on the end. The rotate command doesn't seam to work on sweeps. Is there a way to rotate sweeps at all? or ar they forced to hor and vert?
Wed, May 2, 2012 at 4:54:58 PM | Can you rotate wall sweeps?
Johnzo142
You could try using a fascia with a specified offset?
Wed, May 2, 2012 at 9:23:44 PM | Can you rotate wall sweeps?
phtshpguy
I agree, fascia is a much more powerful tool when it comes to roof edges.  I have used it for gutters(where the drip edge of a roof is not parallel to the ground), I use them for roof ridges, and because they just follow an edge they can be stacked on one another.
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps
Sun, Jul 12, 2009 at 1:54:07 PM
13
Page generation time: 1.1826
