23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Constraint Dimension value does not appear in schedule
15 Posts No Rating |
Hello,
I have started a casework family from the template, but constrain LENGTH value will not appear in the casework schedule.
I was wondering if I have to add/ click/ check somthing in order it to appear?
Your help is greatly appreciated.
Thank you
In order to schedule a parameter from a family, that parameter must be a shared parameter.
Look up shared parameters in your HELP.
Thank you!
EQUAL CONSTRAINT DIMENSION |
Mon, Jan 10, 2005 at 1:06:29 PM
Multiple dimension fields in schedule |
Wed, Aug 24, 2011 at 4:31:08 PM
Elevation Constraint within Instance Parameter |
Wed, Mar 7, 2007 at 9:54:24 AM
Labeling Dimensions |
Mon, Apr 24, 2006 at 1:24:50 PM
Window's dimension don't show up in the window schedule |
Fri, Aug 17, 2012 at 1:34:43 PM
