Forums >> General Discussion >> Revit Project Management >> Client Model Sharing
Tue, May 1, 2012 at 5:55:09 PM | Client Model Sharing
lcox3
I have a large model that I have been working on for a client that has Revit and is familiar with the program. We have just finished the first stage and need to send our model to the client. The model is a Central with Worksets and Linked Files (I would prefer to give the client full control of the elements)
What is the best way to Detach a file as it currently stands while presearving all of the models capabilities (*Without Damaging the Central Model)
Wed, May 2, 2012 at 5:45:54 AM | Client Model Sharing
It really doesn't matter if he is not on your network.  Just send him a full copy - local or a DOS copy of the central.  When he opens it, he will have to create his own central.
Mon, May 7, 2012 at 3:54:05 PM | Client Model Sharing
lcox3
Worksharing has been a very helpful tool in View control of systems and I would like to allow him to use our model with systems already set up in our worksets with out him having to recreate
Mon, May 7, 2012 at 3:57:59 PM | Client Model Sharing
OK Then give him the model and you quit working on it.  Is that what you want?
There is not a way to share your working model unless you set it up on a Revit server or cloud.
Tue, May 8, 2012 at 8:33:25 AM | Client Model Sharing
lcox3
I found a way... I had to open and detach from the central while presearving worksets, then i had to copy all of the linked files to the new directory with the new central and reload them into the project from thier new location. Once this was done I was able to save the Central and reliquish all of my owned worksets. Once the new independant files were created I Zipped the directory and uploaded it to an ftp.
I work mainly for the Manufacturing Industry and the reason I am trying to give the client a working model is so they can do detailed anaylisis of thier facilities systems and equipment. The client owns the model and they should be able to use it long after I am done with it.
Sharing Models
Tue, Jul 16, 2013 at 12:45:36 PM
Giving a 3D Revit Model to a client?
Mon, Aug 17, 2009 at 3:36:10 PM
sharing a model with another firm over FTP?
Thu, Feb 19, 2009 at 12:50:56 PM
Received revit model from client and can't select certain walls
Mon, Apr 4, 2016 at 3:49:04 AM
Submitting model to client
Wed, Dec 30, 2009 at 7:00:18 AM
Page generation time: 0.7193
