Forums >> Revit Building >> Technical Support >> multiple schedules
Tue, May 1, 2012 at 10:05:58 AM | multiple schedules
meridian
for instance im working on schedules for a condo. i want to do one schedule for common areas and another schedule
for just the suites. how would i go about doing this? right now i have created the 2 schedules but all the rooms are
showing up on both schedules and i cant remove them
Tue, May 1, 2012 at 10:26:33 AM | multiple schedules
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
in your schedule properties there is sorting and grouping and a filter areas. I would begin to use those two areas to see if you can get what you need to show by using those option.  without it in front of me and looking at it i really cant say what exactly to filter and sort. But give those a try and should be a good start for ya.
Tue, May 1, 2012 at 1:04:42 PM | multiple schedules
meridian
I knew it had something to do with that and i have fixed the issue
thanks.
Multiple Different Keynote Schedules
Fri, Mar 21, 2008 at 7:34:15 AM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Exporting Multiple schedules to excel at once?
Wed, May 21, 2008 at 10:11:07 AM
Exporting schedules to Excel with multiple lines in a cell
Thu, Jan 24, 2013 at 9:55:29 AM
Export multiple Revit Schedules to multi-tab Excel file
Wed, Jun 2, 2010 at 5:09:12 PM
Page generation time: 1.5513
