Forums >> Revit Building >> Technical Support >> The file is already open for editing by another user. You will unable to save an
Sun, Apr 29, 2012 at 2:13:11 AM | The file is already open for editing by another user. You will unable to save an
tonybonessharp
I've been getting this message when I open my project file. Only I don't have another version of Revit open with the same file or any file as I am not liscensed for more then one. "The file is already open for editing by another user. You will unable to save any changes before that user closes the file." I have looked at the folder options to see if the file is read only and it is not. What's happening?
Sun, Apr 29, 2012 at 9:17:33 AM | The file is already open for editing by another user. You will unable to save an
The file you are trying to edit was created and saved under a different user name.  The user name is set under options in the Revit R pull down.
Can't Save Changes
Wed, Mar 25, 2009 at 5:03:26 PM
Urgent! Help... unable to save
Thu, Dec 20, 2012 at 8:05:42 AM
Can't save work set - help! [ 1 2 ]
Wed, Oct 19, 2016 at 10:03:26 AM
15
Revit Worksets won't sync
Tue, Apr 23, 2013 at 9:52:14 AM
Vista 32, Revit Arch 09, file opening issue
Thu, Feb 12, 2009 at 3:24:23 PM
Page generation time: 0.7922
