Forums >> Community >> Newbies >> cant select object even when I tab.
Fri, Apr 27, 2012 at 9:07:40 PM | cant select object even when I tab.
BlueFairy
I created an object, however I cant seem to select it now even when I tab to find it.  What can be the problem?
Tue, May 8, 2012 at 11:13:23 AM | cant select object even when I tab.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I have heard of a person with this problem and it was because of his video card, once he updated everything was fine.  It may also have to do with your view range, can you select it in any other views?
Tue, May 8, 2012 at 11:22:49 AM | cant select object even when I tab.
Are you using design options?
Tue, May 8, 2012 at 4:38:37 PM | cant select object even when I tab.
Johnzo142
Try setting your visual style to wireframe, sometimes that works for me.
Display shifting in Context tab
Thu, Nov 12, 2009 at 7:21:26 AM
Problem selecting glass using tab key
Thu, Mar 21, 2019 at 1:17:37 PM
Using Tab to select Families in Families
Fri, Mar 29, 2019 at 4:34:49 AM
How to get structural tab?
Tue, Apr 15, 2014 at 12:22:56 PM
Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
Thu, Mar 30, 2017 at 1:15:02 PM
Page generation time: 1.8561
