Forums >> Revit Building >> Technical Support >> modeling sweep/blend/void? - STUMPED
Fri, Apr 27, 2012 at 10:19:09 AM | modeling sweep/blend/void? - STUMPED
nmt80
I'm completely stumped on how to approach this. This is typical for 4 sides. Any advice?
Fri, Apr 27, 2012 at 10:47:13 AM | modeling sweep/blend/void? - STUMPED
nmt80
hopefully this will work
Fri, Apr 27, 2012 at 10:56:04 AM | modeling sweep/blend/void? - STUMPED
rod23
5 Stars: 4 Votes
That's what we call a compound curve.  Last time I had to do this, I was forced to model it in CAD and import.  But that was before the conceptual mass editor.
http://www.turbosquid.com/Search/Artists/Revitaoist
Fri, Apr 27, 2012 at 12:34:56 PM | modeling sweep/blend/void? - STUMPED
You might be able to do this with a solid cut by tw different voids
Fri, Apr 27, 2012 at 12:53:58 PM | modeling sweep/blend/void? - STUMPED
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Swept blends are the only way I can see this accomplished with the basic modeling tools, and it'd be difficult to stay accurate.
EDIT:  this is the closest I could get with a single swept blend, (including a couple void extrusions to trim it nicely)  without spending too much time.
Edited on: Fri, Apr 27, 2012 at 3:48:54 PM
Sat, Apr 28, 2012 at 11:56:49 AM | modeling sweep/blend/void? - STUMPED
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Hello, a form like this can be done by making a flat projection of all the points at the reference level. The edges that are going to be curved in the 3d form are created by a spline of 3 points, and the edges that are going to remain horizontal or straight are created as reference lines. Then you need some reference planes in elevation to control the height of the points. Then, create forms. This is the approximate result. It is possible to make another version with a slight curve in the corner edges, as in the photograph.
Planta1 Revit Online Consulting | info@planta1.com
Void Blend not showing correct cut
Tue, May 5, 2009 at 11:21:00 PM
Sweep Blends / Void extrusion
Wed, Mar 11, 2009 at 2:42:08 PM
Blend sweep problem
Tue, Feb 28, 2012 at 1:51:35 PM
Void Sweep won't cut extrusion
Fri, Aug 24, 2012 at 3:02:42 PM
Void Sweeps
Thu, Nov 24, 2005 at 10:31:45 PM
Page generation time: 0.4607
