Forums >> Community >> Newbies >> Attatching an image to a 'Model in Place' mass
Fri, Apr 27, 2012 at 2:14:19 AM | Attatching an image to a 'Model in Place' mass
DSArchitect
Hi
I am trying to place a decal image onto the face of a mass. Placing an image seems straight forward when placing onto walls, however does not seem to work on mass. Am I missing something, or is it not possible.Appreciate your time
Regards DS
Fri, Apr 27, 2012 at 2:22:29 AM | Attatching an image to a 'Model in Place' mass
DSArchitect
Sorry, should probably add that the decal box looks like it is on the mass, however just will not render.Thanks again
DS
Fri, Apr 27, 2012 at 7:25:39 AM | Attatching an image to a 'Model in Place' mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you assigned any properties to your mass to make it have walls, roof, etc?
Fri, Apr 27, 2012 at 7:47:57 AM | Attatching an image to a 'Model in Place' mass
DSArchitect
Hi Teafoe5
To create the mass, I just went to Component > Model in place > Mass > Drew the area > Create Form > Solid Form > Finish Mass and then extruded to the required height.
I have done this for all the surronding buildings for my site - and I am hoping to attatch photos of the buildings onto the extruded mass, so when I render my site, the surrounding buildings render as well with the photos overlayed
How do I assign properties to the mass?Appreciate your time
Thanks
Fri, Apr 27, 2012 at 9:11:47 AM | Attatching an image to a 'Model in Place' mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to actually turn your masses into buildings by adding walls.  I don't think that you can add a decal to a plain mass.  If you are just adding decals to look like the buildings I would create a generic wall type a random thickness say 2" with the default material used for it.  Once you have your wall type, click the wall button to start creating walls then under draw tab click the "Pick Faces" button (looks like a cube with a green front) and then just select the faces of your mass and it will automatically turn them into walls which you can then place your decals on.
Fri, Apr 27, 2012 at 9:36:34 AM | Attatching an image to a 'Model in Place' mass
DSArchitect
You are brilliant Mr Teafoe5 - works like a charm. Never thought of doing that.
Thanks alot.DS
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
Mass won't export/import
Sun, Jul 23, 2006 at 2:34:08 AM
Create a new family from a 'model in place'
Tue, Jan 17, 2017 at 12:57:22 PM
linked revit model disappears when I edit a floor or do an 'in place' model
Mon, Dec 17, 2012 at 8:01:15 PM
Page generation time: 1.0080
