Forums >> Revit Building >> Technical Support >> Property Lines + True North Rotation
Thu, Apr 26, 2012 at 2:00:45 PM | Property Lines + True North Rotation
Polar
So a while back I read what seemed like a savvy blog entry that seemed to recommend referencing property lines instead of having them directly in the main project file.
So I have successfully entered the property lines using the site and massing property lines table input (attached Revit Architecture 2012 file)
think it - build it
Thu, Apr 26, 2012 at 2:03:43 PM | Property Lines + True North Rotation
Polar
The problem is that I don't think I accurately rotated project north.
So when I referenced the property lines RAC 2012 file into the main project I had to rotate the referenced RAC file.
Then  when I went to label it I couldn't tag the ref'd RAC file's property lines - instead I got the attached error message
think it - build it
Thu, Apr 26, 2012 at 2:09:28 PM | Property Lines + True North Rotation
Polar
Ultimately my goal was to have true north rotated accurately - and have the property lines lable with not only the correct distance, but the correct angle.
I have attached a creen-shote of the RAC 2012 project file that references the property lines created in RAC 2012 with the site property line table interface.
think it - build it
Thu, Apr 26, 2012 at 2:19:17 PM | Property Lines + True North Rotation
Polar
reading this thread now:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6454419&linkID=9243099
think it - build it
Thu, Apr 26, 2012 at 2:30:26 PM | Property Lines + True North Rotation
Polar
ok... removed ref'd RAC file and pasted property lines directly into project file instead. Yea! that is working
...and rotated project north to make rear wall of building parallel to the adjacent property line. More success!
think it - build it
Thu, Apr 26, 2012 at 2:34:45 PM | Property Lines + True North Rotation
Polar
problem solved
think it - build it
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
site orientation
Mon, Feb 18, 2008 at 1:35:35 AM
Rotate true north
Wed, Jan 24, 2018 at 4:20:59 PM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
Turning project true north
Sat, Jan 27, 2007 at 6:42:33 PM
Page generation time: 0.3067
