27 Users Online (25 Members):
Forums >> Revit Structure >> Technical Support >> unable to view vertical rebar
42 Posts No Rating |
hi, so i am working on structure and something is going on with vertical (perpendicular on floor plan) rebar that are not being displayed on the floor plan. it doesnt say it cant add it, i just cant see it when adding and once its added
on the screen shot i have the 3d view to show they are near and not maybe on a different place,
on the section that is going exactle across the column i am able to add and view at the same time any type of rebar without problems
and there is also the floor plan where i can only see the parallel but not the perpendicular one
hope i was able to explain this correctly and really really need help.
thanks in advance
view range on floor plan
Select the rebar and check the "View Visibility States" in the properties box.
still the same, i unchecked and checked back again the view unobscured option and still the same
Rebar Schedule - Right click to Show rebar in View - I see no "Show... " option |
Sat, Nov 22, 2014 at 3:28:11 PM
How to apply the rebar in a ramp. |
Mon, Jul 5, 2010 at 4:53:04 AM
rebar in wall section |
Mon, May 8, 2006 at 10:33:57 AM
Need help to modify rebar bar size!!!!! |
Thu, Apr 6, 2017 at 3:03:05 AM
Revit 2016 - Rebar note |
Wed, Jul 29, 2015 at 9:21:12 AM
