Forums >> Revit Structure >> Technical Support >> Export to DWF vs. DWG
Tue, Apr 24, 2012 at 11:58:36 AM | Export to DWF vs. DWG
DevinBushey
I am having a problem with exporting fill patterns from revit to CAD.
When I export to a DWG, column hatches appear but wall hatches do not.
When I export to DWF the wall hatches appear, but column hatches do not.
Both my columns and walls have the same material assigned to them.
Any ideas?
Tue, Apr 24, 2012 at 3:52:31 PM | Export to DWF vs. DWG
DevinBushey
Nevermind, I figured it out. If you set the view to "wireframe" instead of "hidden line" it works.
Revit MEP 2011 Won't Export dwf/dwg Files
Sat, Oct 29, 2011 at 6:47:43 PM
Help with dwf visible parameters
Mon, Aug 23, 2010 at 2:41:35 PM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:11 AM
help! dwf for 2d plans
Sun, Feb 26, 2006 at 8:15:57 PM
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Page generation time: 0.2585
