Forums >> Revit Building >> Technical Support >> Dormer Help Please
Thu, Dec 22, 2005 at 5:32:42 AM | Dormer Help Please
Nathan
4.5 Stars: 3 Votes
I am trying to edit the roof in the attached file so that there is a dormer over the window on the right the same as the one on the left. I have designed it the same as the other one but keep getting the following error message: Can't keep wall and target joined When I click on show it highlights the rear wall of the building which in no way is connected to this part of the building at all. Any help appreciated
Tue, Jun 12, 2007 at 3:32:33 PM | Dormer Help Please
OPIE
click "ok" when that message apears, if the roof shows up and it looks the way you want it too
"winner"
I have had that message show up 10,000 times i'll bet. i generally ingnore it if the roof shows up and if there is something that has changed ie. a wall has disjoined from the roof i'll fix it when i see it. usually in 3d view is where i find most of the cosemetic errors.
Room bounding in a dormer.
Fri, Nov 8, 2013 at 2:57:00 PM
How can i get a dormer on this type of roof?
Wed, Mar 14, 2012 at 2:58:37 PM
Dormer wall attachment issue
Fri, Apr 15, 2011 at 1:42:00 PM
DORMER ROOF
Sun, Mar 20, 2005 at 6:46:00 PM
Dormer Opening Not Defined?
Wed, Feb 23, 2011 at 7:53:40 AM
Page generation time: 0.0172
