Forums >> Revit Building >> Technical Support >> Help: Print transparent objects from floor plan view to pdf in revit 2013
Tue, Apr 24, 2012 at 11:22:55 AM | Help: Print transparent objects from floor plan view to pdf in revit 2013
a1142730
I just came across this issue. In revit architecture 2013, objects with transparency override won't be printed to pdf properly from any floor plans. For example, to override a slab with 100% transparency in a floor plan view, when going print to pdf or even export to dwg, the slab just turns opaque. if there are walls under it, you won't be able to see the walls in the pdf/ dwg. But this doesn't happen to other views like elevations/ sections/ 3d etc. please see the attached image for details. this never happened in 2012. guess it may have something to do with the new surface transparency feature in graphic override setting.
Can anyone give that a try on your own computer to see if that happens to you as well? if so, i guess we will have to wait for the hotfix to come which is a little frustrating.
Tue, May 8, 2012 at 2:49:41 PM | Help: Print transparent objects from floor plan view to pdf in revit 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes I have that problem also.  You could just hide the object in that view.
Transparent Floor Plan when printing to PDF?
Fri, Apr 17, 2009 at 1:06:25 AM
Electrical shows up in plan view, but will not print.. Help!
Mon, Jul 21, 2014 at 3:04:35 PM
objects in view on sheet set not showing up in PDF
Wed, Jul 10, 2013 at 7:00:02 AM
cant print floor plan to PDF
Mon, Sep 17, 2012 at 8:30:08 AM
Print to PDF with transparent background!
Tue, Jan 25, 2011 at 8:12:03 AM
Page generation time: 3.4150
