Forums >> Revit Building >> Technical Support >> How to print a spacial pattern on glasses or walls
Mon, Apr 23, 2012 at 8:26:28 PM | How to print a spacial pattern on glasses or walls
fairywiner
See, my project picture, I have a special pattern on my glasses. I don't know how to print this pattern on my curtain wall in Revit, what I thougt about is making a sufurface after the pattern, then loading it into Revit, it may be show the pattern, but I think it should be transparent. Are there any other solutions?
沧海月明珠有泪
Tue, Apr 24, 2012 at 3:44:54 PM | How to print a spacial pattern on glasses or walls
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How is this pattern on your wall currenty or is that not your revit model?  You could try adding a large decal to your building but I'm not exactly sure how that would work/look on such a large scale.
Tue, Apr 24, 2012 at 3:49:43 PM | How to print a spacial pattern on glasses or walls
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
well--what IS the pattern, in reality?  How is it going to be built and what is it made of?  It's frosted, on the glass, or exterior filaments/mullions of some sort?
And next--do you have this as an image file?  Does the pattern repeat?
Mon, Jun 4, 2012 at 3:12:33 AM | How to print a spacial pattern on glasses or walls
fairywiner
The pattern does not repeated. I have sent a picture,it's just like my pattern idea, see the dot pattern. I don't know how to "print" this pattern on the glass.
沧海月明珠有泪
Mon, Jun 4, 2012 at 2:18:32 PM | How to print a spacial pattern on glasses or walls
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
If it is not repetitive in some way, then it´s not a pattern.  You might need to model it, or apply it as a decal.
Planta1 Revit Online Consulting | info@planta1.com
Sun, Jul 15, 2012 at 10:05:58 PM | How to print a spacial pattern on glasses or walls
fairywiner
But ,can you tell me how to apply it as a decal?
do I have to model it,  it is not like in the Rhino in which I can project the decal on the surface, I don't have a clue how to make it in
the Revit. Thank you.
沧海月明珠有泪
big glasses
Tue, Jun 23, 2015 at 12:49:29 PM
Fill pattern not showing up in print
Tue, May 1, 2012 at 11:20:14 AM
Fill Pattern not show up when print
Wed, Apr 25, 2012 at 4:08:55 AM
wall pattern not going to edge of walls
Mon, Jun 11, 2007 at 6:46:26 PM
Random Walls not printing the Pattern
Thu, Feb 20, 2014 at 9:21:34 AM
Page generation time: 0.7645
