Forums >> Community >> Newbies >> Visibility
Mon, Apr 23, 2012 at 10:57:35 AM | Visibility
SteeleBallz
I cannot see the vertical conduit in plan view. I know it is possible because there is another model that I've worked in that it was visible. Does anyone know the solution to this problem? I have attached screen shots.
Mon, Apr 23, 2012 at 11:19:03 AM | Visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Check your visability settings under your sheet properties and also make sure you dont have that category hidden.
Mon, Apr 23, 2012 at 12:11:50 PM | Visibility
SteeleBallz
I found the solution. Thank you for your help teafoe, but I could not find the answer I was looking for. In the electrical setting, in MEP settings, under rise drop, in the conduit setting, i had to change the two line symbology.
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
VISIBILITY
Mon, Aug 7, 2006 at 5:36:38 PM
Symbolic Element Visibility
Tue, Feb 4, 2020 at 6:42:28 AM
Controlling window visibility
Tue, May 12, 2009 at 12:49:39 AM
Page generation time: 0.1340
