Forums >> Revit Building >> Technical Support >> How can you place a component's width by picking two points?
Thu, Dec 22, 2005 at 1:24:38 AM | How can you place a component's width by picking two points?
rgesner
I"ve created a parametric family component that works well and with its width as an instance parameter. I'd like to place it and specify the width simply by picking two points, instead of having to pick a point at the midpoint of where I want it, measure relevant adjacent objects to determine the desired width, and then edit its properties to change its width to match. The Modeling Opening tool is placed with two points similarly to how I'd like my family component to work. Thanks - Rusty
B. Rustin (Rusty) Gesner, IT/CAD/BIM Director, Mackenzie, Portland, Oregon - Architecture, Interiors, Structural, Planning, Civil, Landscape, Traffic & Project Management
Thu, Dec 22, 2005 at 3:42:01 AM | RE: How can you place a component's width by picking two points?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If there are instance parameters they should create grips in plan and elevation that can be stretched to the desired size after placement that will snap to adjacent objects. This saves you having to edit the properties and measure the width it needs to be. HTH.
picking points from the 0,0,0 p.
Thu, Jan 22, 2015 at 10:01:40 AM
Create topography from instance not picking up points
Wed, Jan 30, 2013 at 9:51:10 AM
Picking Host
Fri, Oct 3, 2008 at 2:57:27 PM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Voids with gutter profile
Sun, Aug 21, 2005 at 10:00:21 PM
Page generation time: 1.9078
