Forums >> Revit Building >> Technical Support >> Revit 2012 and Revit 2013 simultaneously?
Sun, Apr 22, 2012 at 4:50:00 AM | Revit 2012 and Revit 2013 simultaneously?
nko87
May I install and have working simultaneously Revit Architecture 2012 and Revit Architecture 2013 without any problems between the two versions?
Anyone tried this?
Sun, Apr 22, 2012 at 7:03:48 AM | Revit 2012 and Revit 2013 simultaneously?
4 Stars: 205 Votes
Did you tried????
Sun, Apr 22, 2012 at 7:08:54 AM | Revit 2012 and Revit 2013 simultaneously?
nko87
No, I hadn`t tried. I had a very important project but I want to try the new features of 2013 version these days. So I`m asking does anybody tried to have both installed and working properly?
Sun, Apr 22, 2012 at 7:11:40 AM | Revit 2012 and Revit 2013 simultaneously?
4 Stars: 205 Votes
Yes, I have both installed and working properly!
Mon, Apr 30, 2012 at 5:50:34 PM | Revit 2012 and Revit 2013 simultaneously?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Me too...
Edited on: Thu, May 3, 2012 at 8:05:06 PM
Mon, Apr 30, 2012 at 5:56:03 PM | Revit 2012 and Revit 2013 simultaneously?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I have both running at the moment.  One is doing a walkthrough, minimized in the background, the other I'm drafting with.
I haven't installed 2013 on the other office computers or pushed people to upgrade their projects and get on the 2013 standard yet, because we unfortunately have 1/4 of our office on floating seats, and it's a hassle getting new network licenses from our distributor... and I'm lazy.
Edited on: Mon, Apr 30, 2012 at 5:58:00 PM
Thu, Jun 7, 2012 at 12:40:59 AM | Revit 2012 and Revit 2013 simultaneously?
sedatrende
hello guys,
I just wanted to ask if there is a way to create a project in revit 2013 and work on the same file in revit 2012 on a different computer.
Thu, Jun 7, 2012 at 1:10:23 AM | Revit 2012 and Revit 2013 simultaneously?
DavidBruinsma
In my experience REVIT files are not backwards compatable, so i would answer with NO.
Thu, Jun 7, 2012 at 1:40:11 AM | Revit 2012 and Revit 2013 simultaneously?
sedatrende
I think you are right.Thanks for the reply anyway...
Thu, Jun 7, 2012 at 8:03:32 AM | Revit 2012 and Revit 2013 simultaneously?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
David is correct, REVIT is NOT backward compatable.
Thu, Jun 7, 2012 at 12:16:36 PM | Revit 2012 and Revit 2013 simultaneously?
#11
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I have REVIT ARCH, Struct and MEP 2011, 2012, 2013 installed and working on the same PC. I don't actually use them all at the same time however but I do run some of them at the same time.
It is my understanding that REVIT does not and will not ever have backward compatible file formats. And it's not something I would ever wish for either. Backward compatibility = no forward progression. AutoCAD Architecture is a prime example of that. Dead in the water and grasping for air.
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Upgrading from revit 2012 to 2013
Tue, Apr 23, 2013 at 9:34:40 PM
Upgrading from revit 2010 to 2012
Thu, Oct 27, 2011 at 7:19:24 AM
Autodesk Revit 2013
Fri, Mar 15, 2013 at 3:17:15 PM
Revit 2013 running slow - anyone have the same issues?
Sat, Mar 1, 2014 at 1:37:56 PM
Page generation time: 1.5720
