Forums >> Revit Building >> Technical Support >> bottom view in view range is not active, why?
Sat, Apr 21, 2012 at 6:51:19 PM | bottom view in view range is not active, why?
anis1stnov
I set the cut plane at 1meter but I can see the floor. I tried to change the bottom view but it's greyed out and changing with the cut plane. So I can't change it independently. Can anyone please tell me why the bottom view is greyed out?
I'm using revit 13.
Please help.........
Mon, Apr 23, 2012 at 8:51:56 AM | bottom view in view range is not active, why?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you give me a little more information.  Do you have multiple levels?  Can you attach a pic showing your process and your building.
Tue, Apr 24, 2012 at 7:22:57 AM | bottom view in view range is not active, why?
anis1stnov
Thanks Teafoe5 for your interest. I much appreciate your time.
I think I figured out the problem. I closed revit and reopened the software and it was ok. I guess it has nothing to do with revit as such, but something to do with graphics card or RAM of my computer. It's all working now.
Thanks again.
View Range Revit 2014
Fri, Feb 20, 2015 at 9:55:04 AM
View Range
Tue, Aug 28, 2007 at 9:52:27 AM
View range problem
Fri, Apr 1, 2011 at 12:47:39 PM
View Range
Mon, May 17, 2010 at 4:48:55 PM
View Range
Thu, Oct 24, 2013 at 2:37:43 PM
Page generation time: 4.5744
