Forums >> Revit Building >> Technical Support >> Revit 2011 - Curtain Wall doors on Schedule for correct level
Fri, Apr 20, 2012 at 2:21:11 PM | Revit 2011 - Curtain Wall doors on Schedule for correct level
daxoliveira
I have a 2 story curtain wall. The door on the first floor is showing up on the schedule for the correct level, no problems with it. There is a door on the second floor of the curtain wall, which goes out to a deck. This door is showing up on the door schedule as being on the first floor. I have changed the curtain wall's base constraint to be the second floor and adjusted the base offset for the wall base to still be on the first floor level. Both doors on first and second level still show up as being on the first floor in my schedule. How do I make each door show up on their correct levels in the door schedule?
Thu, Jun 7, 2012 at 1:22:49 AM | Revit 2011 - Curtain Wall doors on Schedule for correct level
DavidBruinsma
The only thing i can think off is to split the certain wall horizontally at the first floor level. That way the ground floor part of the wall and its doors will schedule via the ground floor, and likewise the first floor curtain wall door  SHOULD schedule as a First floor door.
Experiement and let me know if that works.
regards
David Bruinsma
Schedule curtain wall doors
Mon, Mar 20, 2006 at 11:54:56 AM
Schedule curtain panel by level?
Fri, Sep 2, 2016 at 4:40:25 PM
Storefront Doors in Door Schedule
Wed, Sep 9, 2009 at 4:32:17 PM
Scheduling Curtain System doors - will not identify level
Mon, Jan 11, 2010 at 6:40:59 PM
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:11 PM
Page generation time: 4.8189
