Forums >> Revit Building >> Technical Support >> Revit 2012 - Section Tails not draggable
Fri, Apr 20, 2012 at 2:07:43 PM | Revit 2012 - Section Tails not draggable
erickson1026
I am having issues with sections tags that refer to other views not letting me manipulate the length of the tail in elevation view.  Standard section references (ones with an actual view attached) seem to work fine, but when I refer to another view instead, I am not allowed to lengthen or shorten the tail.
Any ideas would be great.
Thanks.
Fri, Apr 20, 2012 at 2:21:56 PM | Revit 2012 - Section Tails not draggable
You do mean the length of the cut line?  That has never been a problem here.  Check your process.  You can select the cut line?
Revit 2009 : Section Tails: How to create custom Section Tails
Thu, Jul 17, 2008 at 3:25:05 PM
Custom Rafter Tails & Roof in Revit 2012
Thu, Aug 7, 2014 at 2:53:02 PM
Section and Detail Tails
Sun, Jun 18, 2006 at 9:30:05 PM
Section Cut tails
Wed, Mar 28, 2007 at 1:46:10 PM
Draggable Line in an Annotation family?
Thu, Jul 5, 2012 at 1:30:26 PM
Page generation time: 2.4384
