24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Interior Window Trim
I am using Revit Architecture 2013. What is the best method of creating window trim on the interior side? I am doing an interior rendering of a bathroom design and I have a window above the soaker tub.
Thanks,
Rob
Place the trim in your window family, or if you only want to do this as a one time thing you can make and in-place component and sweep the trim around your opening.
Thanks! I will give it a try.
Take care,
Rob
window cant tell front from back |
Wed, Jun 22, 2011 at 4:53:19 PM
Window Trim overlap issue help? |
Tue, Nov 13, 2007 at 2:53:11 PM
Tricky Window Trim |
Thu, Mar 9, 2006 at 1:14:00 PM
Wall Sweep only cuts out window not trim |
Mon, Aug 18, 2014 at 10:34:16 PM
Adding exterior trim to window |
Tue, Nov 10, 2009 at 8:27:34 AM
