Forums >> Revit Building >> Technical Support >> Titlte Block causing plot issue
Fri, Apr 20, 2012 at 10:37:45 AM | Titlte Block causing plot issue
BobWeirNC
I have a old title block that prints fine, no issue.  However I am  converting it to update the format of the title block. What I am doing is importing a CAD file and then "tracing" the CAD with Revit lines and labels from the original title block to conform with the CAD file.  Atferwards, I delete the Cad file and load into the project.  However....when I plot 1/2 or full size, every other printhead pass is skewed to the right about a half inch at max speed setting and skewed a fraction of an inch, so it looks as if it is a 3-d image printed in grayscale, at max quality setting...very wierd.
Has anyone seen or heard of anything like this before?
I have tried to make everything on one layer in the CAD file before importing and that has no effect.  The really oddd thing is that it was made 3 months ago and the plot issue started a week ago, so .... I am at a loss.  And now trying to correct the issue by trying the above, which is how I created the first rendition of the new title block that worked for 3 months.  What has changed?
Corrupt file or image maybe?
Fri, Apr 20, 2012 at 11:18:45 AM | Titlte Block causing plot issue
BobWeirNC
Here is the title block that is createing the issues.  Any help/suggestions would be appreciated.
Fri, Apr 20, 2012 at 1:59:34 PM | Titlte Block causing plot issue
BobWeirNC
Figured it out.  Not sure why but, when I make the corner tic marks a complete box the issue goes away.  Not sure if there was some sort of update that made it start to mess up, but by doing that the problem was resolved.
Plot log
Thu, Feb 5, 2015 at 8:06:04 AM
raster image will not plot
Thu, Sep 24, 2009 at 8:43:42 AM
Plot Preview in PDF
Wed, Feb 22, 2012 at 11:28:24 AM
Title Block Issue
Tue, Feb 16, 2016 at 3:52:27 PM
Revit printing issue
Wed, Nov 23, 2011 at 10:36:07 AM
Page generation time: 0.2555
