Forums >> Revit Building >> Technical Support >> exporting demo layers
Fri, Apr 20, 2012 at 8:46:14 AM | exporting demo layers
sgray05
Is there a way to export from revit to CAD and have the demo elements expost as demo layers
Fri, Apr 20, 2012 at 8:54:47 AM | exporting demo layers
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Check out the EXPORTING TO DWG OR DXF in your help.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171/2172-Export2172/2173-Exportin2173/2175-Exportin2175#GUID-42C75024-4D71-4831-8910-2747168624A3
Fri, Apr 20, 2012 at 8:55:38 AM | exporting demo layers
The best advice we can give is TRY IT!   It is obvious that you haven't done so.
Fri, Apr 20, 2012 at 9:36:40 AM | exporting demo layers
sgray05
OK so it took a bit of playing with different phase and phase filters on and adding the modifiers in the expoxt, but I got it.
Sat, Apr 21, 2012 at 8:15:26 AM | exporting demo layers
For others that stumble onto this thread, If you have views that show demolished objects, Revit will automatically export demo'd objects to demo layers using the standard layer setup that is provided.  Nothing special is required other that to have a view set to show the demolished phase.
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:40 AM
Dimensions and Exporting
Fri, Nov 9, 2007 at 2:30:26 PM
Turning off Layers when Exporting to Cad
Wed, Nov 5, 2008 at 6:06:36 PM
Keep .dwg Layers when exporting .rvt to .dwgPlease
Wed, Feb 24, 2016 at 9:27:59 AM
DWG export: room tags to different layers
Tue, Oct 7, 2014 at 7:27:53 AM
Page generation time: 1.3433
