22 Users Online (20 Members):
Forums >> Community >> Newbies >> Ceiling edit boundary problems
5 Posts No Rating |
Hi all,
I have a problem with my lay-in ceiling, everytime I try to edit its boundary the ceiling banishes and the boundary appears on the second level, this is a problem since areas of my first floor do not align with my second floor (different foot prints). thus the boundary floats in spaces with no walls. Is there a setting am I missing?
I am curreently using Revit 2012
thanks
Check your ceiling host level.
Even if the ceiling is hosted on a lower level, you should still be able to edit it from any plan.
5 Posts No Rating |
Thanks for your replying to my post
The host level is the first level flooor and the ceiling is set aT 9' above it.
We also checked on the vicibility graphics, thinking that VG had to do with it, but it didn't solve anything.
I will check on the host level, but I am sure it is set correctly, it is just puzzling cus we have a few projects going and this is the only one with this problem. I should add that the same thing happens while trying to eddit soffits
You say you checked VG. Are all lines on in VG for the plan in question?
5 Posts No Rating |
You got it. Problem solve. The lines were off on my VG, once I turned them on the boundary was editable on the frist level
thank you so very much !!
Beam System is not resetting after I edit the boundary. |
Mon, Jun 15, 2015 at 2:35:42 PM
Background fade during Boundary Edit |
Mon, Nov 3, 2014 at 12:08:31 PM
Interior Elevations - darker irregular boundary lines |
Wed, Oct 1, 2008 at 12:55:15 PM
Barrel Vault ceiling problems |
Mon, Nov 22, 2010 at 4:58:04 PM
Edit Split Face on Ceiling |
Mon, Jan 25, 2010 at 4:42:26 PM
