Forums >> Revit Building >> Technical Support >> Elevation Tag Issue
Tue, Apr 17, 2012 at 11:54:51 AM | Elevation Tag Issue
esahnow
Revit 2012
I modified the elevation tag to look like our ACAD standard. The circle diamater went from 1/2" to 3/8" and now my sheet callout number is not aligned and I can't figure out why. I've attached an image of it for clarification.
Any suggestions?
Eric Sahnow
Project Lead/Designer
Tue, Apr 17, 2012 at 2:47:01 PM | Elevation Tag Issue
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It would help if you attached your actual family.  Are they aligned in your family and not when you bring it into a project?
Tue, Apr 17, 2012 at 2:55:26 PM | Elevation Tag Issue
esahnow
Here is my family. Everything looks good to me, I tried to adjust as little as possible.
Thanks for your help. This one has me frustrated.
Eric Sahnow
Tue, Apr 24, 2012 at 11:38:29 AM | Elevation Tag Issue
esahnow
Anyone have any luck with this issue? I'm tempted to just resort back to the stock 1/2" circle that works but it looks WAY too big on the sheet and does not match our office standards.
Eric Sahnow
Wed, Apr 25, 2012 at 10:50:16 AM | Elevation Tag Issue
Polar
The advice I've heard is:
1. if you want different tag sizes create and load them at the beginning of a project
2. make a template with the tags already loaded
Not much help mid-project though....
think it - build it
Sim location issue on Elevation tag
Wed, Nov 5, 2008 at 11:50:16 AM
Changing the size of the interior elevation tag
Wed, Dec 20, 2006 at 12:26:41 PM
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Revit 2018 Elevation Tag Location
Fri, Jul 28, 2017 at 12:26:32 PM
Page generation time: 3.3433
