17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> DIMENSION TEXT
6 Posts No Rating |
Is there a way to insert an ENTER SPACE in the "Below" field of a dimension?
In other words, I want to make my text two lines. Cant figure it out
Sorry there is not a way to do this. You would have to create your dimension and then add text to get it this way if you had to.
CAN YOU PLEASE EXPLAIN WHAT IS IT THAT YOU WANT.
6 Posts No Rating |
I want the text to be in two lines. No matter how much i type it comes up in one (long) line.
Sorry but I don't believe you can have two lines here. You may try this:http://revittotd.com/07/527
but I doubt if it will work here.
Dimension Text [ 1 2 ] |
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text |
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension |
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem |
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension |
Thu, Apr 2, 2009 at 9:47:51 AM
