Forums >> General Discussion >> Revit Project Management >> Revit 2012/Globe Link
Thu, Apr 12, 2012 at 8:51:37 AM | Revit 2012/Globe Link
jibro77
I am trying to acquire site from GE to Revit 2012. I've went thru the steps of updating registry to allow Revit add-in to be able to use GE 6 version. (http://revitclinic.typepad.com/my_weblog/2011/06/revit-globe-link-adding-newer-versions-of-google-earth-for-publish-functionality.html
But when I go into add-is and try to acquire from GE, I get the following error. "you must turn off the google earth's feature Terrain before acquirement", which in GE setting, I've already turned off.
Anyone have solution to this?
Thanks in advance!
Thu, Apr 12, 2012 at 1:04:49 PM | Revit 2012/Globe Link
rod23
5 Stars: 4 Votes
Double check, no, triple check your version of GE is compatible with the current Update you have installed for Revit.  I noticed your link was a year old.
http://www.turbosquid.com/Search/Artists/Revitaoist
Thu, Apr 12, 2012 at 1:06:53 PM | Revit 2012/Globe Link
jibro77
I double checked.. I followed the instructions on that link, but used my own GE release number and key for registry...
Fri, Apr 13, 2012 at 5:12:19 PM | Revit 2012/Globe Link
michaelmasteller
I've done the same update to the GEVersions.dat file with GE version 6.2.1.14 (beta) Build Date 2/2/2012 and get the same message in Revit.  I've searched for a solution with no success and welcome a reply from anyone who has found one.
globe link problem
Sat, Aug 8, 2009 at 9:44:23 AM
Creating a mass of globe/ Continents
Mon, Apr 30, 2012 at 12:42:26 PM
recit 2012 default template link - Rmy
Mon, Mar 3, 2014 at 7:50:02 AM
kml kmz file to google earth
Mon, Jan 30, 2012 at 5:02:43 AM
REVIT GLOBE LINK
Thu, Aug 14, 2008 at 5:45:35 AM
Page generation time: 1.9967
