Forums >> General Discussion >> Revit Project Management >> Linking consultant models from an earlier version
Wed, Apr 11, 2012 at 5:37:40 PM | Linking consultant models from an earlier version
juliep
If I have built an arch model in 2012 can our structural model be built and linked in an older version?  What do you do if your consultants do not have the same version you are currently running?
Thu, Apr 12, 2012 at 8:03:11 AM | Linking consultant models from an earlier version
This is one of those Revitisms ... "You have to think ahead".  Revit has never been backward's compatable.  You can not open or link in a later Revit model than the Revit seesion you are in.
Mon, Apr 16, 2012 at 5:51:01 PM | Linking consultant models from an earlier version
revitape
revitape Avatar
4.5 Stars: 9 Votes
Yes Revit is not backward compatible, but technically you can link an older model without it directly affecting that disciplines original model. Revit will upgrade the linked model for the session you are working in (and continue to do so whenever you open your file with that one linked in) but it will obviously not affect the original linked consultant file.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Tue, Apr 17, 2012 at 7:45:48 AM | Linking consultant models from an earlier version
revitape....
You missread the original post.  The poster wants to go the other way.
Tue, Apr 17, 2012 at 9:09:55 AM | Linking consultant models from an earlier version
revitape
revitape Avatar
4.5 Stars: 9 Votes
Ah I see that now. My bad!
CONSULTANT USING VERSION 12... IM USING VERSION 13...
Wed, Dec 19, 2012 at 9:52:05 AM
Linking Other Models
Tue, Aug 31, 2010 at 1:35:54 PM
Linking the Autodesk Advanced Models Together
Mon, May 19, 2014 at 2:02:04 PM
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
How do we retain visibility graphics settings for our consultant files?
Thu, Mar 12, 2015 at 2:18:49 PM
Page generation time: 0.7566
